Suutsin kudagi oma auto võtme ära kaotada ja võtsin kasutusele varuvõtme. Sellel aga oli vahepeal patarei tagant ära ja on suutnud auto ära "unustada". Kas keegi teab, kuidas neid omavahel tutvustada. auto on 97a ja võti on kolme nupuga (kinni, lahti ja salongivalgustuse süütamine).
Tänud juba ette.
BMW E36 võti.
BMW E36 võti.
"Player In Maneagement Profession"-PIMP
- Kris K
- Peamine sõiduk: E90 318iA '06
Re: BMW E36 võti.
--Close all doors, windows, trunk, and hood
--Open drivers door, sit in seat, close door
--Turn Key to On (2nd Position) do not turn on car
--Turn Key to Off
--Turn Key to Off
--Turn Key to Off
--Turn Key to Off
--Turn Key to Off
(must turn on and off 5 times ending in off position)
--Led should light
(the whole procedure must take place within 45 seconds)
Samuti võid seda proovida:
1. Close the doors, hood, and trunk with car unlocked.
2. Open the trunk lid.
3. Open the driver’s door.
4. Sit in the driver’s seat.
5. Close the driver’s door.
6. Put the key in the ignition. You must do these first five steps within 45 seconds.
7. Cycle from the off position to the (“almost start”) second position five times. Do this step within 10 seconds.
8. Open the driver’s door.
9. Close the driver’s door.
10. On the remote: Press the large button.
11. On the remote: Press the small button.
12. On the remote: Press the large button and hold until it flashes once.
13. On the remote: Press the small button and hold until it flashes once.
14. Up to four remotes can be recognized by the car’s alarm system. As they are recorded, the oldest remote information will be overwritten.
15. Open the driver’s door.
16. Get out of the car.
17. Close the trunk lid.
18. Close the driver’s door.
19. The programming is complete.
20. Test the new remote(s)
21. Enjoy
--Turn Key to Off
--Turn Key to Off
--Turn Key to Off
--Turn Key to Off
--Turn Key to Off
--Led should light
21. Enjoy
sillufromIV
Re: BMW E36 võti.
Kas on keegi sel moel puldid tööle saanud?
Kas võib võtta suvalise töötava e36 puldiga võtme ja ümbertutvustada oma autole? Või peab olema uus (varem tutvustamata või mingil moel resetitud pult)?
Viimati muutis sillufromIV, 14.06.2015 19:49 21, muudetud 1 kord kokku.
Suzuki GSX 750 WR; Skoda Rapid Scout, Berlingo 2001, Vivaro 06, H1 06, Jimny 99 ja Samurai 02.
Re: BMW E36 võti.
Esimese versiooniga sain sõbra võtme oma autole tutvustatud. Ehk siis ei pea olema uus!
