Selleks tee nii:
1. Turn Radio Off.
2. Turn Radio On.
3. Press and hold the "m" button for about 10 seconds.
4. Press < or > to navigate, you will need to go to the 2nd screen to look for the SW Verison which is in a SV xx-xx xx format.
5. To be Sirius/AUX or XM compatible, the radio must be SW 43 or higher.
6. Turn radio off to exit.
Makk ise peab olema tehtud 09/02 või hiljem. Minu makil on see nüüd küljes, ning paremat asja ei oskagi tahta.
