E39 Kuidas saab teha nii, et sõiduajal näeks TV-d?
530td
Postitus Postitas 530td »
Kuidas teha 1999a. E39 bemmil nii, et sõiduajal saaks näha telekat?
Nagu sõitma hakkad ütleb, et:
"Sinu enda turvalisuse pärast ei saa TV-d sõiduajal vaadata"
Tahaks sellest lahti saada. Mida pean tegema ja kuidas?
Igatahes need soovitused ei aita:
http://www.zone.ee/e38/tips.htm
Abi oodates,
BMW530td
530td
Lahendus:
Kes otsib see leiab...
Lahendus probleemile on järgmine:
Watch TV / Videotext during driving
This works on all 5/7 Series with the Mark I Navigation System (the one with the male voice).
On Mark II (the newer version with the female voice) you have to use "brightness" instead of contrast for TV and "color" instead of brightness for videotext to get the trick to work.
This works on the latest 99 7-series models as well. This does not appear to work for the latest BMWs sold in Europe (2000 onward, 3/5/7 series). The software updates for latest navigation CD-ROM's do not appear to affect or disable this trick.
set ignition to pos. II
enter TV mode
enter "settings"
enter "contrast"
when the green contrast bar is visible, push the knob and keep it pressed
turn ignition off (keep button pressed!)
wait 8-10 seconds (timing must be accurate!)
release the knob
turn on ignition again
Now the TV will operate while the car is in motion, though you certainly should leave that to your passengers only while driving.
To watch videotext use the same procedure as above, but choose "brightness" instead of "contrast" (thanks to Herbert Posner, who discovered this secret).
Kaidos
Postitus Postitas Kaidos »
Ma küll ei kujuta ette, kuidas keegi saab sellise asja "avastada". Peab ikka aega olema. :D
Kristjan_K
pigem vastav tehnika..
ottOmar
Peamine sõiduk: Mercedes-Benz CL55
Postitus Postitas ottOmar »
tean, et uuel S-klassil on seda trikki pea võimatu teha
on küll võimalik, aga rahakott peab seljas olema.
isegi mu ema sõidab BMWga
ahtil
Postitus Postitas ahtil »
Suured tänud 530 td! Lähen proovin enda autol täna seda samuti. Kas sa juhuslikult ei tea kas on juba ilmunud või olemas mõni kaart Eesti kohta (pidasin silmas navigatsiooni)?
530td
Tsau
Tean küll...
Navigatsiooni asjus pööra pilk politsei autosse ;)
Neil viimasepeal navi kaart olemas CD peal.
Kui keegi selle kätte saab siis andke teada! Tahan ka...
ahtil
Re: Tsau
Huvitav, huvitav. Kas sa nägid liikluspolitsei autos või liikluse erirühma autos?
530td kirjutas:Tean küll...
Alar_P
Postitus Postitas Alar_P »
Politseil pole navi kaart vaid tavaline linna kaart CD-l, seal peal teiste patrullide asukoht.
R4, R6, V6
530td
2006
Alles a. 2006 pidi tulema meile navi plaat.
Aga seoses autode häkkimisega, kas keegiteab veel mingeid nippe?
Samalaadseid nagu teleka konf, et näitaks ka sõiduajal.
Mulk
Peamine sõiduk: A6 4G QUATTRO
Postitus Postitas Mulk »
Tänu soome foorumlastele sain oma navile(mk3) uue softi sisse ja kogu menyy ja graafika muutus paremaks.Käivitamisel ilmub bmw logu ekraanile ja 2004-2005 teleatlas navi cd toimib väga hästi nüüd ka siin skandinaavias. meeldiv oleks jah et ka eesti kaart oleks olemas. igasugu nippe on ka lehel bmw.bazzi.biz
ahtil
Kas sa osakad äkki abi anda Navi kohta. Minul aasta 1998 auto e39, kas sellele leidub kuskil uus soft? Kahjuks ei tea mis tüübiga tegemist. Tean ainult niipalju, et Naviteq. Endal olemas aastast 1999 Saksa teleatlas CD.
mulk2 kirjutas:Tänu soome foorumlastele sain oma navile(mk3) uue softi sisse ja kogu menyy ja graafika muutus paremaks.Käivitamisel ilmub bmw logu ekraanile ja 2004-2005 teleatlas navi cd toimib väga hästi nüüd ka siin skandinaavias. meeldiv oleks jah et ka eesti kaart oleks olemas. igasugu nippe on ka lehel bmw.bazzi.biz
Mulk
to ahtil
kas sa soome keelt natuke jagad? kui siis otsi www.bmwtuningclub.net lehelt tekniika alt teema bmw navigaatio ja sen päivittys. Kui sa ei leia siis ma vöin lähiajal otsida kui aega saan. Iga tahes lyhidalt mingilt lehelt tuleb endale cd -lekirjutada uus soft ja see siis omasse navisse laadida. Lehe nimi oli midago nero .com taolist. Seal foorumi lehel täpne aadress. nii et suurem töö on siis see soft seal pladile kirjutada auto navisse laeb ta automaatselt kui softiplaat sisse panna. Sinu navi arvatavasti mudel mk2 . Ma vöin kaa otsida e4hk on mul saadetud privapostis alles sönum mille 530td saatsin, saadan siis sulle ka sama .
jevgeni
Postitus Postitas jevgeni »
Alar_P kirjutas:Politseil pole navi kaart vaid tavaline linna kaart CD-l, seal peal teiste patrullide asukoht.
siin ma küll vaidlen vastu. minu teada neil on uus Regio atlas arvutides.
BMW is lifestyle
X5 3.0d e53 ´05
Mulk
arvutis olev kaart nüüd küll ei näita nende olemist kaardil oleval tänaval, auto liikumist, ummikute olemas olu, auto liikumist kaardil, infot et lyhem tee, kiirem tee jne. gps navi kaart ikka ju midagi muu kui tavaline cd olev kaardi programm. või olen vales? kui eesti kaarti oleks siis ju ma arvan et nii audi, mb, bmw, subaru jne. oleks selle myymisest huvitatud, kui kaart siis ka ju lihtsam uuele auto ostajle navit auto lisaks müüa. ise asi kui autos on oma läpakas, siia juurde gps seade jane siis saab jah maastikul orijenteeruda jne.
ahtil
Tänud Mulk2 :) Hakkan sinu antud aadressilt täna infi otsima.
Eesti kaart esialgu puudub, vähemalt Naviteq jaoks. Millised kaardid olemas saab vaadata Navteq kodulehelt: http://www.navteq.com/ProductFinder?Lan ... h=coverage
pets1
Postitus Postitas pets1 »
jevgeni kirjutas:
Laptopides ja muudes seadmetes kasutatavatel kaarditel/atlastel pole midagi ühist navikaartidega.
Sellist GPSi ja läpaka ristsugutist kasutasin ma juba pea 10 aastat tagasi eesti metsades.
Aga kuna Eestis navi ei tööta ja seega enamik inimesi pole seda loogika järgi elusees näinud :) (ärge lööge!), siis:
Laulab, tantsib ja lööb trummi ka vajadusel. Igati mugav kasutada koos häälega :)
mulk
Postitus Postitas mulk »
Endal kasutuses 2 kaarti, 2002 /4 golden bmw edition europa ja 2004/2005 teleatlas skandinavia koopia. ja tänu uuele softile saan ka ekraani poolitada ja vaadata kaarti ja noolesuundi sama aegselt. ikka väga mönus vööraid tänavaid kas või helsinkisgi leida. ka naised saaksid köik aadrssid ylesse leitud :lol: jah tore oleks ka eesti oma olla, näitab ka köik kraadid ja minutid maakardi järgi + körgus merepinnast ja aeg ka sateliidi pealt.
Mulk
imelik ka nime mulk all olen sisse logind kuigi mulk 2 peab olema. kaarte ja navisysteemide versioone ka lehel www.teleatlas.com vist tuli öige aadress. siin köik kirjas ka auto margi järgi saad plaadi valida. mul oli kuskil teisel lehel sama plaat hinnaga 170 eur siin lehel 159 eur hinnka skandinaavia versioonil. igatahes hea ja täpne on .
põrnikas
GPS & TV
Postitus Postitas põrnikas »
Kas on võimalik kuskilt kopeerida skandinaavia Navi plaati?
ja
Kuidas saab teleka näitama 2001 aasta E39 mudelil?
alziz
Peamine sõiduk: X5
Postitus Postitas alziz »
Mis udu te ajate? Laptopile on Eesti GPS kaart ammu olemas. Regio Atlas 3.6 Müüakse Elionis ja paljudes muudes kohtades (maskab ~850.-). Sul peab olema laptop ja gps seade (maksab ~1400.-). Siis saad koguaeg vaadata, kus sa oled (kõik tänavad ja puha). Saad teha, et soovid minna punktist A punkti B ja sulle näidatakse teed. Ainuke puudus on see, et teedel pole suunavööndeid... ehk teid võidakse juhatada linnas sõites ühesuunalise tänavat vastasuundas kasutama. Lisaks ei tule suurt nooleksest, et keera siit tasakesi paremale jne.. vaid pead kaardi pealt vaatama, et mööda ei paneks... aga mul pole sellega probleemi olnud. Laptop'ile oleks sel juhul hea autolaadija või voolumuundur osta, sest akust võib väheseks jääda...
Autode navi plaati aga veel ei ole. Läbirääkimised käiva Regio ja autoplaadite tootjate vahel. Regios öeldi, et kõige varem võib tulla autodele eesti kaart 2006 aastal... aga võib ka hiljem tulla.
Võib olla keegi on nii tark, et oskab tavalist CD atlast ise BMW Gps süsteemile arusaadavalt plaadile konvertida? See oleks ka päris hea....? Netist kahjuks selle kohta infot ei leidnud aga äkki ma ei otsinud piisavalt.
Aga igatahes laptop'ile on väga töötav kaart olemas. Ise kasutan.
alziz kirjutas:Võib olla keegi on nii tark, et oskab tavalist CD atlast ise BMW Gps süsteemile arusaadavalt plaadile konvertida? See oleks ka päris hea....? Netist kahjuks selle kohta infot ei leidnud aga äkki ma ei otsinud piisavalt.
Mingi võimalus peab olema, sest venkudel on BMW CARiN/VDO seadme jaoks olemas Moskva kaart. Kui seda DB faili vaadata, siis leiab sealt seest sellised read:
no label
no description
1. name: moscow demo v2.4
2. content: moscow city, russia
3. oem: unknown
4. supplier: unknown
7. conv tool version: shp2vdo 2.19.615
8. conv input files:
9. conversion date: 30-Dec-03 11:52
10. db release number: 16
11. conversion remarks: superblock width 0x120000, angles fix, adaptive junction attributes, no street numbers, no POI, no landuse, no RDS/TMC
Pane tähele p.7.
Ivar
Re: Lahendus:
Postitus Postitas Ivar »
530td kirjutas:Kes otsib see leiab...
enter TV mode
enter "settings"
enter "contrast"
release the knob
Minu MK II -s 99a autos ei tööta :( proovisin nii ja naa, mitte ei saa. 97 a MK I-s toimis kenasti.
priit0001
navigatsiooni teema
Postitus Postitas priit0001 »
Kui BMW-l on tehase poolt paigaldatud navigatsioonikompuuter CARIN, PHILIPS või VDO, siis nendes saab kasutada VDO Daytoni navigatsioonikaarte. Maailma suurimad navigatsioonitarkvara tootjad on Teleatlas ja Navteq. Eelpoolmainitud kompuutrid töötavad mõlema valmistaja kaartidega. Balti riikide ja venemaa kaart tuleb suure tõenäosusega VDO-l müüki järgmisel aastal.
Täpsemat infot leiab:
http://www.vdodayton-shop.com/start.asp ... ShowLand=1
2005/2006 kaardid on eestis (KG Knutsson) saadaval märksa odavamalt kui vdo online-shopis.
tel. 5088118
Axxept
Postitus Postitas Axxept »
selline küsimus, et kust ma üldse kindlaks saan teha mis soft praegu on.
masinaks on 1999.a. E39.
530i E39, 530d E39 & 325i E30
Muhv
Postitus Postitas Muhv »
Vaatan, et keegi pole siin uuemate autode TV küsimusele veel vastanud.
Seega - kui "nupu trikk" ei tööta tuleb Top Vox'ist ehitajate tee ääres või Top Audiost Rock 'a keskusest osta vastav adapter ja see siis vajalikku kohta pista.
Mingil ajal peaks väidetavalt Alptomi jõudma ka miski aparatuur, mis siis on võimeline asja ka tarkvaraliselt korda ajama.
Laialt levinud on siiski vaid need adapterid. Kes soovib, võib ka e-bayst osta, ainult kui viimati uurisin jäi mulje, et odavamalt kui koha pealt ostes sealt ei saa.
