M: Sonnax ZF8HP käigukasti zip kit ZF 8HP45/55/70
Postitatud: 18.01.2025 07:57 41
				Müügiks uus Sonnax ZF8HP käigukasti zip kit. Sobib järgmistele ZF käigukastidele 8HP45/55/70. Komplekt asub Tallinnas ja hinnaks küsin 150.-. Huvi korral saatke pm.
Sonnax Zip Kit ZF8-ZIP targets the root cause of multiple complaints by sealing the critical circuit pressure losses in the ZF8HP45/55/70 valve bodies. The kit contains uniquely designed parts to prevent the loss of pressures within the main line, solenoid regulator, reverse, clutch control and solenoid apply circuits with no special tools required.
The Zip Kit quick guide provides clear and easy instructions on one sheet to get the unit sealed up and back on the road fast. In addition to general rebuilding tips and technical information, the technical booklet included in this kit contains vacuum testing and additional repair options for higher mileage units or for repairing specific complaints which are beyond the scope of this kit.
Drop-in Zip Valve™ parts install quickly and easily, no reaming or special tools required
Uniquely designed parts address root causes of valve body complaints by sealing critical pressure circuits
Detailed technical booklet included with in-depth rebuild and inspection tips for comprehensive valve body repair
