Problem with steerling !
Hi there.
Car bmw 118i year 2009 mileage 135k
I change steeling rack because i had fail sign because of sensor inside engine rack. After the service change my steering rack when i turn left and right make a noise like a clicking noise i never had this problem before with the old one! Whats the problem? Maybe they didnt change good the steerling rack? If somebody can help please let me know.
Thank you
Thank you
- RazzKalbass
- Peamine sõiduk: E39 525TDS
Re: Problem with steerling !
Maybe it also needs a aligment job.
I did also aligment! Its mandatory after change steering rack to do the aligment...
- RazzKalbass
Take it back then
Doesnt help me with nothing ur reply! But thanks anyway
This is best help he can give you with your information you have given.
There are some people here on forum who have enough experience to answer correctly questions that are very specifically asked. You have not done that. Remember, giving attitude here only gets you less help from them.
I guess it’s eps not hydro rack ( sensor inside rack)
Did you install used or new?
Clicking coming where? Under bonnet, into frame, near steering wheel?
Clicking starts when? Start of turning, when start applying torque? On turning, in certain degrees of turns, equally? Something else?
This is how specific questions are asked
So! Yes I changed the steering rack with a new one not used. Clicking is heard inside the car and outside the steering wheel where it is steering is heard when I drive left and right it doesn't matter which way I go ... only when i drive the car slow (10 20 km per hour) or when i stay park it sounds the best. Immediately after I took the car from the service I noticed this noise that I did not have with the old steerling rack. I went back to the service and I was told that maybe it's new to drive for a few days and then if it keeps doing the sounds to come back for check.
That's why I addressed this forum because I don't think if i drive few days sounds will disspear and maybe someone will give me some advice ... shouldn't I have mounted the steering rack properly? Thanks
Now read this to your self loudly and try to imagine that you are explaining it to person who havent heard the sound. Imagine you are writing computer code like this…
Is it constant clicking not dependent on degrees you turn, or it comes on certain degrees of turning and repeats after certain degrees?
This conversation feels like pulling teeth out
