Kas e46 kõrvalistuja turvapatju saab ise välja lülitada?
rixa
Postitus Postitas rixa »
Kas e46 kõrvalistuja patju saab ise välja lülitada? Autoks on siis 2001 aasta 330xd. Olen kuulnud, et UM'is saab, aga kas ise ei saa - kui turvatooli pole, siis võiks ju töötada?
Mis mõttes? Kui seal keegi ei istu, ongi ta välja lülitatud.
rixa
priitv8 kirjutas:Mis mõttes? Kui seal keegi ei istu, ongi ta välja lülitatud.
Mõtlesin seda, et kui sinna lapsetool panna. Osadel autodel on mingi süütevõtmega lüliti, mis laseb siis välja lülitada.
Ingmar
Postitus Postitas Ingmar »
Ja mind huvitaks, kas turvapadi avaneb ka siis, kui turvavöö lahti?
http://foorum.bmw-club.ee/viewtopic.php ... 5&start=57
Kui uskuda kasutusjuhendit, siis
Before installing any child-restraint device or child seat, please read the following:
Never install a rear-facing child restraint system in the front passenger seat of this car. Your car is equipped with an airbag supplemental restraint system for the front passenger. Because the backrest on any rear-facing child restraint system (of the kind designed for infants under 1 year and 20 lbs./9 kg) would be within the airbag's deployment range, you should never mount such a device in the front passenger seat, as the impact of the airbag against the child restraint's backrest could lead to serious or fatal injuries.
If it is necessary for a child (not an infant) to ride in the front seat, certain precautions should be taken. First, move the passenger seat as far away from the dashboard as possible. This important precaution is intended to maximize the distance between the airbag and the child. Older children should be tightly secured with the safety belt. Younger children should be secured in an appropriate forward-facing child restraint system that has first been properly secured with a safety belt. Never install a rear-facing child restraint system in the front passenger seat. We strongly urge you to carefully read and observe the instructions for installation and use provided by the child restraint's manufacturer whenever you use such a device. Be sure that all occupants (of all ages) remain properly and securely restrained at all times.
Vt. http://www.e38.org/2001Manual-7Series.pdf lk 57-62, 161, 188
rixa
Tänud. Eks tagumine parempoolne iste ongi kõige turvalisem koht lapsele.
rixa
Panen siia ka UM'i vastuse, kui kellelgi teisel peaks kunagi huvi tekkima.
UM:"seda on võimalik teha tehase testriga, aga enne peate vahetama auto turvavöö nn. mittejärgiandva turvavöö vastu, mis tagab lasteistme tugeva kinnituse."
