Tervist,
Oleks soov nullida microfiltri service aeg. Aga hetkel seal polegi aega, ega kilomeetreid ja seega ei õnnestu kuidagi seda nullida.
Siiamaani on aidanud alljärgnev õpetus, aga hetkel see ei toimi. Näitab küll et teeb reseti, aga numbrite asemele jäävad ikka kriipsud.
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
Ja Idrive menüüst ei saa ka uut aega määrata.
Paar pilti:
http://www.hot.ee/fackit/pilt/DSC00467.jpg" onclick="window.open(this.href);return false;
http://www.hot.ee/fackit/pilt/DSC00468.jpg" onclick="window.open(this.href);return false;
Soovitusi?
E91 Microfilter reset??
priitb
- Peamine sõiduk: F31 325d
Re: E91 Microfilter reset??
Youtubes mitmeid videosid sellest. Roolialt kangiga lähed servise menüüsse, otsid mikrofiltri ülesse, vajutad nuppu(või hoiad all?) tuleb kiri reset, vajutad uuesti ja asi ants. Kirjutasin mälu järgi ja umbes nii see asi käis? Suurt ekraani polnud vaja vaadata igatahes.
BMW f31 325d 160kw 2014a
Ülevalpool ma just kirjutasin, et sedamoodi hetkel ei toimi. Kõike muud saab seal teha, aga microfiltrit mitte, kuna seal ei ole märgitud vahetamise kuupäeva, ega kilometraasi. Asi on sellest ajast, kui sai kuupäev, kellaaeg ja keel jne ära nullitud. Arvasin, et ehk saab miski nipiga selle tagasi, aga paistab et ilma arvutita mitte.
- TiitR
Ma ei tea kas sellest infist on kasu, kuid kui oma kunagise e60-ga UM-is käisin erinevaid asju nullimas, ütles sealne tehnik, et kui nullitav asi pole nö. miinusesse jooksnud (jäägu või 1km.), siis saab nullida vaid arvutiga....muidu, aga autost?
Aga sellest autost on mul 4,5a. möödas kah, vb. on asi vahepeal palju muutunud juba?
