Huvitavad BMW müügikuulutused
fedja
Peamine sõiduk: Ühistransport
Postitus Postitas fedja »
Mis sel mootoril siis teistmoodi on võrreldes 236kw mootoriga?
lahjem on tunduvalt ju :D
Madis.
Postitus Postitas Madis. »
Üles pimbitud M52.
fedja
toivoku kirjutas:lahjem on tunduvalt ju :D
Jah...:D
Mõtlen natuke täpsemalt.
mall0c
Postitus Postitas mall0c »
Pmtslt stroker teravamate nukkadega.
Raghza
Peamine sõiduk: M340i xDrive
Postitus Postitas Raghza »
fedja kirjutas:Mõtlen natuke täpsemalt.
Wikipedia kirjutas: S50B30US
USA versions of the 1994-1995 E36 M3 are powered by a 3.0L tuned version of the M50 which produces 179 kW (240 hp). This engine was based on the M50B25TU and uses the same compression ratio, but uses a different crankshaft, connecting rods, and pistons. At the 1996 facelift, this engine was replaced by the 3.2 L S52.
The S52 is a higher performance version of the M52 which used for the post-facelift (1996-1999) North American E36 M3, replacing the S50B30US.
Compared to the S50 engine used elsewhere, the S52 is less powerful and features more in common with the regular M52 engine. As per the North American M52 engine, the S52 uses an iron block, aluminium head and single VANOS. Unique to the S52 is a bore of 86.4 mm (3.4 in) and stroke of 89.6 mm (3.5 in) for a total displacement of 3,152 cc. The engine is rated at 240 hp (179 kW) at 6,000 rpm and 236 lb·ft (320 N·m) of torque at 3,800 rpm.
Other upgrades over the M52 include lighter camshafts with more lift and duration, piston rings, valve springs and the exhaust system.
Madis.
mall0c kirjutas:Pmtslt stroker teravamate nukkadega.
Bore on ka suurem.
Lauri1
Peamine sõiduk: VOLVO XC60
Telefon: 56999266
Postitus Postitas Lauri1 »
Sten.H
Peamine sõiduk: BMW X5 3.0d E53 FL ´04
Postitus Postitas Sten.H »
Sellel kuulutusel peaks veel Individual kiri ka olema kuna haruldane 2.9 V6 170kw diisel ka aiste vahel :shock: :mrgreen:.
BMW X5 3.0d E53 FL Maritime 2004 (160kw/500Nm)
Chris_P
Peamine sõiduk: BMW E46 328iT
Postitus Postitas Chris_P »
Telefonis keeruline kopeerida aga kes otsida viitsib, siis autorahaks poistel on makroflex edition masin müüa. :lol:
Tauri_J
Postitus Postitas Tauri_J »
Mingi Honda oli, nüüd BMW ka või? :lol:
karmo
Postitus Postitas karmo »
Seitsmene bemm e38 on neil mingi kameeleon edition,äkki on isegi siia postitatud,ei ole väga lapanud :D
RagnarV
Postitus Postitas RagnarV »
tegin sellest pullist screenshoti isegi mõnipäev tagasi :D
jaanis_!
Peamine sõiduk: X5 E53
Postitus Postitas jaanis_! »
Kena rull http://www.auto24.ee/used/2212462" onclick="window.open(this.href);return false;
deniilov
Peamine sõiduk: a6
Postitus Postitas deniilov »
http://www.auto24.ee/used/2215145" onclick="window.open(this.href);return false;
tundmatu e34
reino
Postitus Postitas reino »
Mis põhjusel tundmatu? Siin foorumiski olnud.
E82
Sarkasm. Rändkarikas ju.
Investor
Postitus Postitas Investor »
Red M3:
http://www.auto24.ee/used/2216639" onclick="window.open(this.href);return false;
Leedu
Peamine sõiduk: M4
Postitus Postitas Leedu »
Tehasest hõbedane ja PAREMPOOLSE rooliga. Arvele ei saa. Huvitav et kuulutsues pole mainitud.
agentzero
Peamine sõiduk: F06 640d
Postitus Postitas agentzero »
Pukseerimiskonks ka ilusti küljes ikka :lol: Võiks siis pildi jaoks vähemalt ära kruvida selle sealt.
Reimers
Peamine sõiduk: ST450
Postitus Postitas Reimers »
Kirjutab ju et veepump andis saba sellest ka konks :D
Jaanssn
Peamine sõiduk: E92 325i
Postitus Postitas Jaanssn »
Muidu paarutas leedu nr-iga nüüd eesti transiidid pand.
Tauri_J
Seda on proovitud autoplussis ka leetu ja lätti müüa. Siin vaevalt lahti saab.
because
Peamine sõiduk: E36 328i M-pakett
Postitus Postitas because »
Tuttava oma, leedust toodud küll jah aga võin väita et väga hästi hoitud ja hooldatud tema poolt, kõik mis vahetust vajanud on tehtud. Eestis arvele saamisega jah võimalik et probleeme, aga suveks ikka ülimõnus pill nautimiseks. :P
BMW E61 3,0D - BMW E91 2,0D - BMW E92 3,0D - BMW E60 3,5D - BMW F01 4,0D - BMW F11 3,0D - BMW E92 3,5D - BMW E91 2,0D - BMW E60 3,0D - BMW X6 3,5D - BMW F10 3,0D - BMW F10 3,0D
Reimers
Kuskohas seda siis nautida kui regada ei saa ? 12k põllurallikas või
Donald
Postitus Postitas Donald »
Ringrajal.
Mis ringrajal?!
Selleks, et piima (loe: madalal lennata) saada ei ole vaja teatavasti lehma (loe: Gallardot) osta. :mrgreen:
http://www.auto24ring.ee/est/teenused/3 ... gallardoga
because
Reimers kirjutas:Kuskohas seda siis nautida kui regada ei saa ? 12k põllurallikas või
Ei jah, Eestis ei saa ju selle autoga ringi üldse sõita kui regatud pole.. :lol:
Tauri_T
Postitus Postitas Tauri_T »
because kirjutas:Ei jah, Eestis ei saa ju selle autoga ringi üldse sõita kui regatud pole.. :lol:
Kas sa ostad siis endale auto mida ei saa Eestis arvelegi ja sõidad sellega paar aastat ringi, kuni leiad järgmise lolli kes sõidab samuti paar aastat jne.. Mõistlik tegevus. :lol:
Ainus variant kusagil naaberriigis arvele võtta ja seal kindlustus ka teha. Vähemalt viimati kui mina uurisin, siis Eesti kindlustused ei kindlustanud välisriigis arvel olevat sõidukit.
