Videod
tanele28
Postitus Postitas tanele28 »
E28 525e & E28 535i
Roland325
Peamine sõiduk: BMW 650
Postitus Postitas Roland325 »
Päris hea video
Roland325
Äkki see - Krt ei tea, mis jõud seal peab olema, seieri järgi kuskil 180 juurest võttis veel ratta ringi :shock:
Silwer
Postitus Postitas Silwer »
Tuunitud 318is:
Silwer
Mootoriks on vast ikkagi S42 mis vahetas välja S14 mootori. Ehk siis Motorsport aretis M42 (318is) baasil. See oli siis see 2,0 mootor millega võisteldi E36 kerega.
Pilt kah:
"The S42 engine was a 2.0L touring car engine with a 86.5mm bore and around a 85mm stroke, which shared the same block as the street going M42. Unlike the common M42, the S42 had a more sophisticated engine management system, and had individual throttle bodies. The S42 unfortunately did not share the same valvetrain as the M42, and is a solid lifter valvetrain (possibily from the S50Euro) fully capable of over 9000rpm, but was limited to a 8500rpm redline, as dictated by touring car rules. It was mounted upright in the bay, not slanted, and ran on a full dry sump oiling system. The pistons had a static compression ratio of around 12:1, and running on pump gas, the S42 made around 280hp (and up to around 310hp later in it's life)."
Jõunumbreid tegid need mootorid siis:
S42/95 FIA 2.0 L 300 hp - 255 Nm
S42/96 FIA 2.0 L 308 hp - 260 Nm
S42/97 FIA 2.0 L 315 hp - 260 Nm
* veel mõni aeg tagasi ei teadnud ma midagi sellisest mootorist. Herr Lill tegi sellest juttu ja siis otsisin netist tiba infot lisaks.
Alates 2006 on selline: http://www.totalmotorsport.com/Features ... .asp?ID=28
erik
Peamine sõiduk: 530D E60
Postitus Postitas erik »
Venelane võtab päris julgeid poognaid oma m3ga.
http://www.youtube.com/watch?v=TUv6csbt ... ed&search=
jockker26
Postitus Postitas jockker26 »
Väike crash.
erik
Roland325
Minu üks lemmikuid viieseid :shock:
joh
Postitus Postitas joh »
Roland325 kirjutas:Minu üks lemmikuid viieseid :shock:
Oyea, see on väga hull aparaat!
SIIN veel üks, vähe pikem video eelpoolmainitud norrakate M5st...
erik
silver
Postitus Postitas silver »
M1 sound:
http://www.myvideo.de/watch/1812224
Registreerunud kasutajad saavad siit ka ilusaid pilte samalt ürituselt vaadata:
http://forum.e34.de/thread.php?threadid=84283
Elmut
Postitus Postitas Elmut »
http://youtube.com/results?search_query ... NG&search=
Head videod kohtumistest,muusika (Y)
Roland325
Elmut
Väga kurb:( :(
Roland325
Üks e30 325 jälle vähem :(
Henrik88
Postitus Postitas Henrik88 »
Lahe M3
E36 325tds; E36 316i Compact
BMW on BMW
Elmut
Liiga kenad;)
Cardo
Postitus Postitas Cardo »
Hannes
Peamine sõiduk: E91 325d
Postitus Postitas Hannes »
http://www.liveleak.com/view?i=9ca_1184789773
see mõjus bemmi mainele küll hästi :D
(OO==[][]==OO)
KRANTS
Postitus Postitas KRANTS »
miks paljudel bemmimeestel närvid liiga kiiresti üles ütlevad :?: :shock:
Vaadake mis juhtub :!:
alguses pildimaterjal- MIS JUHTUS, pärast lõpus video- KUIDAS JUHTUS :!: :mad:
Candid Camera:
Roland325
Üpris "kihvt" kurv
darklight
Postitus Postitas darklight »
:cool:
erik
Mardo
Postitus Postitas Mardo »
