E34 esivõre eemaldamine
Raigo_E34
Postitus Postitas Raigo_E34 »
kuidas eemaldada E34 esimese võre katet?
selle pildi peal
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
detail number 10.
H_Margus
Postitus Postitas H_Margus »
Pealt kruvid lahti ja vaikselt sikutad, eriti ettevaatlik ole otsa kinnitustega.
Laur
Postitus Postitas Laur »
http://www.bmwe34.net/e34main/maintenan ... adlamp.htm
Teema on küll esitulede vahetus, kuid esivõre eemaldamine on üks selle protseduuri eeldustest.
1. Removal of the center grill is difficult. The plastic retaining clips at each side (behind the lowbeam lamps) are totally blind so you have to know in advance which hidden plastic tab to push on with a 10" long and narrow screwdriver. Cast a shop light on the back of the headlamp assembly and look down the access hole for these two locking tabs. You will not see the tabs, but you will see a set of holes cut out of successive body panels. You screwdriver passes through these. Try to center it in these holes laterally, and bias the screwdriver toward the front of the holes. If you feel it hit something slightly springy, then the tip is on the retaining tab. You have to push quite hard to get the tab to release the side wing part of the center grill. Even with the tab release, it took a lot of prying pressure to get those wings loose with a screwdriver.
Be careful not to scratch the paint. See Bentley manual for pictures.
BMW 549i/6
pikk66
Postitus Postitas pikk66 »
Viimastel kordadel olen esistange enne maha võtnud, sest otsa kinnitusi on väga s*** lahti saada, kui stange kyljes. Kokkuvõttes võidad ajaliselt ja kindlasti säästad hulga närvirakke :)
BMW-le kindel
Roland325
Peamine sõiduk: BMW 650
Postitus Postitas Roland325 »
Stange maas lihtsam jah. Stange eemaldamine minutite küsimus.
markx
Postitus Postitas markx »
Alustada stange maha võtmisest.....muidu jäädki kiskuma ja vanduma, lõpuks võtad ikka saha eest ära ja siis harutad edasi. E34 puhul on kogu see esiotsa kinnituste asi täiesti üle mõistuse.....selleks et mingit pulka kätte saada peab enne kõik teised küljest ära korjama.
Nagu öeldud- stange maha (kuigi sõber Velts võttis mingi valemiga ka ilma stanget maha võtmata nina puhtaks) ja edasi on juba loogika küsimus, pole siin mingeid skeeme ega midag vaja ;)
Roland325
Saab väga ilusti ka ilma stanget maha võtmata aga peab teadma, kus need kinnitusnagad asuvad ja õige kruvikeerajaga õigesse kohta vajutama. Kui aga esimest korda üldse teha, siis on lihtsam/mõttekam stange maha võtta.
Marko S
Peamine sõiduk: E90 335i
Postitus Postitas Marko S »
AARE530 kirjutas:Nagu öeldud- stange maha (kuigi sõber Velts võttis mingi valemiga ka ilma stanget maha võtmata nina puhtaks) ja edasi on juba loogika küsimus, pole siin mingeid skeeme ega midag vaja ;)
Ma sain ka esimese korraga ilma stanget maha võtmata nina puhtaks.Midagi keerulist seal küll ei ole :P Veidi loogilist mõtlemist ja pusimist ning käes ta ongi!
Just because they pull up next to you, doesn't mean they want to race. But better safe than a loser. :D
