Diiselkütuse lisand ?!?!
simmo
Postitus Postitas simmo »
Kas keegi teaks mõnda head diiselkütuse lisandit, mis puhastaks nii pumba kui pihustid? Huvitaks just sellised, mis oleks tõesti ikka väärt kraam!!
Tnx
525 tdsa Touring E34 95a
Õlide ja määrdeainete hulgimüük!
lauri86
Postitus Postitas lauri86 »
Valdekul oli midagi päris head pakkuda, pidavat aitama. helista talle ja küsi ise järgi.
320d `02
Viljar
Postitus Postitas Viljar »
Kui garaasi jõuan, siis vaatan nime üle, igati hea kraam ja annustamine umbes 70 kütuse kohta 30-40 ml (potsik ise 500ml-ne).
Mercedes-Benz EQS SUV 450 4-matic 2024
Mini Cooper S Chilli 2007
Andrei8
Lisand
Postitus Postitas Andrei8 »
Mis lisandi nimi siis oli ja kus müüa?
Andrei8
Lisand
No ja nüüd siis kodanik Viljar kadunud ja vastust ei kuskil, mis mõte on mainida et vot oli kord hea lisand jne kui asja nimegi ei tea!?
Kalla
Postitus Postitas Kalla »
Biodiesel Additive cleans the entire fuel system, prevents seizing and gumming up of the nozzle needles and protects against corrosion and age-induced deposits. Biodiesel combusts more efficiently and consumption is reduced.
Operational area: For all diesel vehicles, including those with state-of-the-art diesel oxidation catalytic converters. Product can be added to fuel at any point in time. Mixing takes place automatically. 250 ml will treat a max. of 70 liters of biodiesel fuel.
Hind 50 eeki.
Protects the components of the fuel system (especially Common Rail Diesel) against wear, corrosion and deposits. Increases the lubricating action of Diesel fuel.
Operational area: Suitable for all Diesel engine vehicles with Common Rail injection systems. Add the contents of the can to the fuel when filling up. 250 ml is sufficient for up to 70 litres of fuel.
Hind 47 eeki
Life is a ......
Kalla
Teine variant ,et tuled läbi Kadaka pst.165a ja ma tutvustan Liqui Moly teisigi tooteid.Tel.5115870
Life is a ......
Andrei8
Lisand
Vohh, super!
Nüüd siis vähemalt teavad ka teised millisest lisandist on juttu, tehke ikka asjadele millest vähegi kasu on ka korralikku reklaami. Nii nadu teeb seda Truumu kui soovitab Kleen-Flo tooteid kuna asjad tõesti mõjuvad.
Kas Tartus kusagil on ka seda müügis, ise nimelt Tartu mees kuid kui Tlna satub kaalub läbiastumist.
Suured tänud
Andrei8
Lisand
No nii, kes otsib see leiab!
Palju infot ja kasutajate vastukajad nimetatud firma toodetele: http://www.liquimoly.ru/
Kalla
http://www.liqui-moly.de/
JA saksa kodukas siis siin. :D :D :D :D
Life is a ......
motuli oma asoovitati mulle väga tugevalt ja proovin selle ka mingi hetk ära.
Andrei8
Lisand
Viljari öeldu "Kui garaasi jõuan, siis vaatan nime üle, igati hea kraam ja annustamine umbes 70 kütuse kohta 30-40 ml (potsik ise 500ml-ne)."
LIQUI MOLY-l ei ole 500ml potsikuid just palju diislile, ainult 1 kui ei eksi, vähemalt koduleht andis nii, see huvitav, mis lisand see sellise suhtega paaki läks. Ainuke mis oligi 500ml potsku, siis see ei olnud mõeldud paaki ajamiseks vaid midagi peab seal enne lahti kuskil ühendama ja siis laskma kuskilt läbi joosta.
Kalla
Aru ma ei saa miks peab potsik just 500 ml. olema.Osta siis kaks 250 ml. ja ongi 500 ml. :D :D
Asi ju lihtne
Life is a ......
lauri86
nüüd tuli meelde,et see mida valdek pakub ongi motul vist, oli 500 ml ka vist.
320d `02
Andrei8
Lisand
Ei ei, ega potsik peagi just 500ml olema, lihtsalt eelpool öeldud, et oli 500ml potsik.
Motulil on tõesti diislilisand olemas kuid vaid üks ja Motul on midagi muud kui Liqui Moly. Viimane peaks etem ikka olema, tootesortiment on samuti oluliselt suurem.
Viljar
näe jama, olin täna just garaazis ja unustasin vaadata :cry: homme vaatan asja üle.
Andrei8
Havi mälu kui unustad nii sageli ;)
Viljar kirjutas:näe jama, olin täna just garaazis ja unustasin vaadata :cry: homme vaatan asja üle.
Vilts on nagu kuldkala. Mälu täpselt 3 sekki. :D :D :D
Cardo
Postitus Postitas Cardo »
Mul sama haigus altsaimer lihgt
Andrei8
Lisand
Äkki keegi teab kus Viltsil garaaaz on, läheks ja vaataks kuhu ta kadunud on. Mine tea äkki vajus uks kinni vmt. ;)
Andrei8
Viltsist
Ilmselt on Vilts juba garaazis surnud, sest väljas juba sellised külmad.
Äkki keegi läheks ikkagi ja tooks mehe tuppa sooja koos vajaliku infoga lisandi kohta ;)
simmo
:D
Mägilane
Re: Diiselkütuse lisand ?!?!
Postitus Postitas Mägilane »
simmo kirjutas:Kas keegi teaks mõnda head diiselkütuse lisandit, mis puhastaks nii pumba kui pihustid? Huvitaks just sellised, mis oleks tõesti ikka väärt kraam!!
Tnx
Valdekul on Motuli kütuselisandid, ühed vähesed lisandid mille mõju ka tunda oli :!:
BMW touring
Andrei8
Lisand
Kes ja kus Motuli kütuselisandeid Eestis müüb?
Seda infot ikka pole.
Liqui Moly on nüüd teada aga Motul mitte!
Mägilane
Re: Lisand
Andrei8 kirjutas:Kes ja kus Motuli kütuselisandeid Eestis müüb?
Valdek müüb www.hot.ee/impulss
BMW touring
cuda
kleen flo
Postitus Postitas cuda »
ise kasutan kleen flo lisandit mis on sellises valge rohelise kirjus plekkplännis 500ml maksis 160.- ja see on mõeldud mingi terve tonnile küttele segamiseks ja tundub küll et pihustiotsad on ilusti puhtad(ei mingit tõrkumist) ja käima saan ka ideaalselt iga ilmaga. Veel panen ma kütusele juurde kahetaktilise õli(addinol) sest tangin alexelas :D
BMW 325td 93`
Toots
Peamine sõiduk: Peamine sõiduk ei ole bmw. Pühapäev: e34 550i V12
Postitus Postitas Toots »
polar pidi ka hea firma olema,ise ei kasuta,kuna pole diislit.
