Huvitavad BMW müügikuulutused
VerineVelg
Peamine sõiduk: BmW
Postitus Postitas VerineVelg »
http://www.auto24.ee/2357076
Paar kõlarit ikka on.
Bayerische Motoren Werke.
kaspar
Peamine sõiduk: BMW M440i xDrive G22 LCI
Postitus Postitas kaspar »
LINK - AUTO24
Varustus on suht kehva (kui M-pakett välja jätta), mootor jõuetu, seisukorra kohta ei tea samuti midagi ning läbisõidu varjamine on ju alati kvaliteedi märk eksole :D :D aga värvi ja M-paketi kombo on päris äss.
S1lv3r
Postitus Postitas S1lv3r »
Veidi käredam ikka kui tavaline 320i. Need erimudelid on kõik m-paketid.
S1lv3r kirjutas:
Esmapilgul tunduvad kõik olema täis m-paketiga.
Tegu on iseenesest päris huvitava pilliga ehk 320si 127kw. Arvasin algul, et omanik üritanud vähe atraktiivsemaks üritanud kuulutust teha, kuid wikist leidsin infot.
It is a limited (2600 units) version of 3 Series saloon built to qualify the homologation requirement for the FIA World Touring Car Championship (WTCC).[36] The 320si uses a modified 4-cylinder engine (N45) different from the standard 320i (N46). Modifications include an increased redline to 7.300 rpm, a shortened stroke (by 2 mm), an increased bore (by 1 mm) and a higher compression ratio (11,0:1). The engine is mostly hand-built and does not have Valvetronic, decreasing the number of moving parts. Acceleration from 0 to 100 km/h (62 mph) takes 8.1 seconds and acceleration in fourth gear from 80 km/h (50 mph) to 120 km/h (75 mph) takes 7.7 seconds compared with a standard 320i which achieves them in 9.0 and 9.1 seconds respectively. Fourth gear acceleration is comparable to that of the 325i which achieves the 80 to 120 km/h (50 to 75 mph) sprint in 7.5 seconds. BMW WTCC works driver Andy Priaulx won two of his three consecutive World Championships in the 320si E90 as well as four other drivers achieving over 35 wins in the championship since the cars release.
The BMW 320si is used by a few teams in the British Touring Car Championship (BTCC). Colin Turkington won the 2009 BTCC Drivers championship using the BMW 320si.
kaspar
Oo, tänan info eest, sain ka targemaks :D :cool:
Keegi, kes e90 otsib, võtke ära :D
Jaakk
Peamine sõiduk: BMW 525i E60 2007
Postitus Postitas Jaakk »
Väga ei soovita seda si-d osta kui mootorit ei taha remontida.
S1lv3r
Kahjuks ei ole neil mootorid kõige vastupidavamad...
Mingiaeg sai neid Saksast piilutud ja enamus olid mootoririkkega.
http://www.hthoward.co.uk/engine-machin ... k-repairs/" onclick="window.open(this.href);return false;
Seda kuidas täpselt sama ettevõte suutis teha ~15a varem 320iS mis arendab 141kw ja põhineb äärmiselt tugeval ja suurte silindrivahedega M10-l ja hiljem sellise nikerdise jääb selgusetuks :lol: :lol:
Maario80
Peamine sõiduk: Audi A5
Postitus Postitas Maario80 »
Tundub sama auto mis leedu platsil paar kuud tagasi seisis :D
mkb
Postitus Postitas mkb »
Lk 304:
Jaakk kirjutas:Nagu sa isegi tead siis need si autod ei hiilga just oma mootori vastupidavuse poolest. Mobiles oli vahepeal vähemalt 10 autot saada millel kõigil kas mootor päris laiali või kolin sees.
S1lv3r kirjutas:Korra varemgi Eestis 320si müügis olnud. Pakkus täitsa huvi, aga uurides selgus, et enamus mis saksas müügus olid mootoririkkega ja ei pidavat väga kestma...
oo7 kirjutas:Tundub veidi müstiline et 25a tagasi suutis sama autotootja teha 320iS, millel on 141kw ja mootor äärmiselt vastupidaval M10-l põhinev S14. Nüüd ei suuda isegi seda jõudu välja anda ja ei kesta ka :lol: :lol:
Deja vu.
S1lv3r
Nii? Oleks pidanud vahepeal uue jutu välja mõtlema? :lol:
Tuleb ka järgmisele sama vastus, kes asjaga kursis pole ;)
mkb
Ega midagi katki polegi, aga tundus kuidagi tuttav see jutt. Otsima hakates oli isegi kaader sama.
Rivitult.
Kordamine on tarkuse ema,
Next time kui asi üles kerkib võid uuesti kopeerida :lol: :lol:
-myyr-
Peamine sõiduk: E46
Telefon: 56846122
Postitus Postitas -myyr- »
http://www.auto24.ee/used/2238660" onclick="window.open(this.href);return false;
hahahah :D
Ehk pole läbi käinud
VerineVelg
Peamine sõiduk: BmW
-myyr- kirjutas:http://www.auto24.ee/used/2238660
hahahah :D
Mai saa aru?
S1lv3r
Foorumihunt rasskalbass ju :D
VerineVelg
Peamine sõiduk: BmW
Ülikena ikka :cool:
Harru
Peamine sõiduk: BMW e61 530d
Postitus Postitas Harru »
Kurikuulus x6 M valmis saanud ja juba müügis, kahju. Aga minu meelest ülikõva tulemus!
RazzKalbass
Peamine sõiduk: E39 525TDS
Ei ole veel päris valmis, kohe saab stanged ka külge, muud pudinad on küljes.
:cool:
Miskitrohelist
Peamine sõiduk: bmw e36 320i sedaan
Postitus Postitas Miskitrohelist »
Harru kirjutas:Kurikuulus x6 M valmis saanud ja juba müügis, kahju. Aga minu meelest ülikõva tulemus!
miskil põhjusel vöörandamis keeluga. :roll:
raunoh
Peamine sõiduk: Passat CC 4MOTION 13`
Postitus Postitas raunoh »
Miskitrohelist kirjutas:
järjest paugutatakse teemasid, mis mõni hetk tagasi juba läbi käinud
Tauri_J
Postitus Postitas Tauri_J »
siit teemast mopiga üle käidud
raunoh
Tauri_J kirjutas:
krt nii ongi
Oli ka aeg.
VerineVelg
Peamine sõiduk: BmW
kekuleku
Peamine sõiduk: Bmw M5
Postitus Postitas kekuleku »
Käisin vaatamas kuu tagasi. Vajab investeeringut mootori tuli põles, roolivõim ei töötanud korralikult, kliima ei töötanud, armatuur imelikult tehtud, tagastange istus imelikult.
-myyr-
Peamine sõiduk: E46
Telefon: 56846122
asi minus, või lihtsalt liiga odav
http://www.auto24.ee/kasutatud/auto.php ... rhash=d848" onclick="window.open(this.href);return false;
Oliver.L
Postitus Postitas Oliver.L »
Paras hind auto vanust ja läbisõitu vaadates minu arust. Full options, aga musta lage, head up displeid, katuseluuki ikka ei silma. :mrgreen:
See auto nii tihti müügis, et kas a) on korralik "rändkarikas" või b) ei õnnestu müüjal sellest kunagi lahti saada ja pidevalt uued kuulutused.
S1lv3r
Omanikuvahetusi paar tükki on, aga müügis jah pidevalt olnud... odavat ei ole seal midagi.
Paras puzzle on :lol:
