5 pluss--kala-- kirjutas:vaata koledatestZipp kirjutas:No Slava, link ka juurde ikka
Huvitavat laiast maailmast
- Zipp
- Peamine sõiduk: E36>E46>E93>F30>Audi>G20
- Zipp
On veel mingit infot või foorumi linki selle kohta?
- e36 in progress...
Väikene E30'ne modifitseerimine:
http://www.youtube.com/watch?v=Y75DjjZm ... ature=fvwp
Hamann BMW X6M Tycoon Evo M 2011
http://www.modifiedcars.com/cars/36505/ ... 1-pictures
peaks nagu dry nos kit olema. Ei saa aru, kas siis kütuse kompenseerib mootor ise või pihustavad ka seda juurde...
Njää, pole asjatundja
lugemist: Dry Nitrous Kit
The typical dry kit is one of the most simple kits available. The kit is called "dry" because it injects only nitrous into the engine, and not fuel. Generally, the dry kit is for people who want a set that allows them to let the ECU or computer automatically add appropriate amounts of fuel to compensate for the added nitrous into the motor. Usually you can get away with a dry nitrous system if you are confident in your car or truck automatically compensating fuel, you have a larger fuel system, or have a way of ensuring there is adequate fuel when the nitrous gets injected.
Wet Nitrous Kit
The typical wet kit is only of the more popular nitrous kits amongst enthusiasts. The wet kit injects both nitrous and fuel into the engine at the same time. As with the dry kit, you still need to have enough fuel in your fuel system for the wet nitrous system to be able to use while the nitrous is being injected. You can setup an external fuel pump specifically for this kit, so when the nitrous is activated, the fuel will come with the external fuel pump, bypassing the stock fuel system. This is a more elaborate wet nitrous system, but can be one of the most reliable setups.
Article Source: http://EzineArticles.com/2279980
Wet Nitrous Kit
BMW Lo Rider (2009)
http://motorcycle-desktop-wallpapers.bl ... rance.html
http://www.motorcycledaily.com/2008/11/ ... mwconcept/
On ka teada, mis nendest masinatest lõpuks sai, kas jõudsid tootmisesse?
Ma kahjuks pole ise juttu läbi lugenud.
Masin(ad) mulle iseenesest väga meeldivad.
- Kivissaar
- Peamine sõiduk: Ducati
- Telefon: 56863083
**** mind huvitaks kuidas ta kere ära toestas. omal kunagi oli sarnane idee e34jaga aga kahjuks ei jõudnud niikaugele.
vöiks ju arusaada et kui inimene enivei Passatiga söidab on ta juba eos elule käega löönud nii et vahet pole mis velg seal talvel all on
Vana asi aga huvitav lähenemine. BMW M5 Turbo
http://www.youtube.com/watch?v=mfIszlnp ... 4CBC5071AF
Bmw e39 523i ///M-sportpakett; Bmw e34 525i; Opel Calibra 2.0 i sport; Volkswagen Polo
- captjones1
Henri_J kirjutas:]
Stirling Moss ei ütle sulle ilmselt mitte midagi?
- oo7
- Peamine sõiduk: BMW 330Ci
Herr Moss oli võidusõitja.
Mismoodi see selle jubeda esiotsaga Z3-ega seotud on
Vaata Striling Mossi McLaren SLR-ioo7 kirjutas:Herr Moss oli võidusõitja.
- oo7
Tean mis autost jutt, lihtsalt see Z3 ei näe kaugelt ka isegi natukene sarnanegi välja
Stirling Mossi originaal võislusmasin veelvähem
Muidu tuuleklaasi idee on hea... Mingi Porche mudel on samuti madala klaasiga ja näeb päris uhke välja, lihtsalt see neerude ära kaotamine muutab selle auto koledaks
Keegi kingitust tahab?
Sihuke kingitus oli täna Viimsis:
- tarvo525i
- Peamine sõiduk: E61 530d LCI
hea kink
- HeavyCuda
- Peamine sõiduk: põrkepall
Kellegi rikka võsuke sai endale esimese auto ???
e36 coupe in progress.....
Üldiselt olen korduvalt seda siin foorumis maininud aga peab vist kordama... Teiste rahakotti ei ole vaja uurida ning mis vahet seal on kes kellele mida kingib. Pole mõtet kohe hakata sildistama "kellegi rikka võsuke".
- HeavyCuda
Coley, ära seda nüüd isiklikuks tee
Ei või enam midagi naljaga poolekski öelda
- Henri.
- Klubiliige - admin
- Peamine sõiduk: 328 kuut
Vaevalt, et keegi 333MUSi nr-ga autot oma tütrele või veel vähem pojale kingib - ju seal ikka üks tegus naiska mängus on
Täna päeval sai kindlustuse ka;
Kehtiv alates 20.05.2011 16:33
Vaadake pilte parem - 328 Homage Concept
- Zipp
Järjekordne X6M Tallinnas
Ja kui rajapäevalt tulles rehvid autosse ei mahu
Keegi meie foorumist ehitab?
Bristol 400
Bristol 401
Bristol 401
