kmn stanced E36 325i Cabriolet on Carline's!
Postitatud: 04.09.2013 13:50 21
Hi all,
hereby presenting you my longtime neverending project. I live in Finland and originally brought this car 3-4 years back from Estonia (Valga to be exact), so this might be familiar for some of you people.. Would be nice to hear some details of the history of this car, if possible?! The car had Rondell 58's on it when i bought it, but after this the car had 3 different wheel setups including BBS RS replicas, 10x17 Rondell's all around etc.. Also the car had been repainted with Jaguar Sapphire Blue metallic at some point for whatever reason..
This is how the car looked when i bought it:
And this is how it looks now...
Original options-list:
Vehicle Information:
Order options
No. Description
209 LIMITED SLIP DIFFERENTIAL (25%)
240 LEATHER STEERING WHEEL
290 BMW LM-RAEDER 7JX15,225/55R15V
314 HEATED WINDSCREEN WASHER NOZZLES
380 HARDTOP PREPARATION
388 SOFTTOP BLACK
395 ROLL-BAR PROTECTION SYSTEM
398 SOFTTOP OPERATION, ELECTRO-HYDRAULIC
423 FLOOR MATS, VELOUR
428 WARNING TRIANGLE
464 SKIBAG
481 SPORT SEATS F DRIVER/FRONT PASSENGER
494 SEAT HEATING F DRIVER/FRONT PASSENGER
498 HEADRESTS IN REAR, MECHANIC. ADJUSTABLE
510 HEADLIGHT BEAM-THROW CONTR. F LOW BEAM
660 BMW BAVARIA REVERSE RDS
676 HIFI LOUDSPEAKER SYSTEM
690 CASSETTE HOLDER
801 GERMANY VERSION
848 ENLARGED WIRING HARNESS
Modifications made my me (6/2013):
Options:
- 18-button OBC with check controll
- OBC remote turning signal stalk
- M3 leather vader-seats
- M3 steering wheel
- M3 gearshift knob with illumination
- E36 BMW OEM wind defelctor
- Wheels Carline CM6, front 10x17 with 3,5" outer lip ET7 and rear 11,5x17 with 4" outer lip ET13
- 8000K Xenon's on high, lows and fogs
- 60SMD Led Angel eyes with dual-remote relay (interior lights and parkights)
- US parkilight mod with OEM US parts
- Smoke front turning indicator lights
- Chrystal red/white tail lights
- Led licence plate lights rear
- Led interior lights (allso at hardtop)
- Facelift smoke side indicator lights
- Hardtop
- Softtop module speed indicator pass-through (roof is able to be controlled also on the move)
- Kenwoodin USB/AUX/MP3
- DLS CA-12 1 x 500W(1 Ohm) mono-block with GroundZero 1F
- Monacor Carpower Sonic 10MK2 2x 2Ohm sub
- Subwoofer box ~46L with 77/40mm reflex pipe, tuned at ~25Hz
Chassis:
- ALL chassis bushings replaced with Strongflex red (including rear axle carrier)
- Front lower wishbones have M3 eccentric Powerflex's
- Rear axle carrier has M3 reinforcements welded
- BC Racing BR height- and suspension adjustable coilovers
- Coilovers with custom spiring length and stiffness (160mm/10kg ja 120mm/14kg)
- Uniball adjustable camber plates on the front
- M3 rear stabilizer
Technical:
- Dual mass flywheel replaced with single mass
- E36 320 -91 sprung clutch setup with E21 323i bearing
- M3 254cc fuel injectors
- ECU modified for E85 fuel
- Catalysts are emptied
- Thermostat changed to 88c and added electric fan
- Matt black cross support in the engine bay
Bodywork:
- M3 front bumper
- M3 rear bumper
- M3 brake ducts
- M3 side mouldings
- M3 facelift -look black front grill kidneys
- Facelift front wings
- BMW badges removed from bonnet and truck lid
- Antenna removed
- Rear fenders pulled HARD
- Front fenders pulled HARDER..
- The whole car is repainted to original Mauritiusblau Metallic on 6/2013
So i guess that's it for now.. Next off i'm gonna swap some Hellgrau M3 interior with vader front seats - they should arrive next week! Then some more pics!
Order options
No. Description
388 SOFTTOP BLACK
464 SKIBAG
690 CASSETTE HOLDER
801 GERMANY VERSION
Options:
- M3 steering wheel
- Hardtop
Chassis:
Technical:
Bodywork:
- M3 front bumper
- M3 rear bumper
- M3 brake ducts
- M3 side mouldings
- Antenna removed
