kas keegi teab või saab vaadata nt. autodata'st, mis vea annab kood nr. 8.
ette tänades,
wilks.
e36 automaatkasti veakood
- Juhtmejupp
Mudel ja kast??
ELECTRONIC TRANSMISSION CODES
4HP22/4HP24 (EARLY MODEL THROUGH 10/89) - EGS 1.XX
08 Solenoid valves 1 & 2 EGS pin 16, 17 Transmission pin 5, 6- Short in wiring
Defective valve winding
4HP22, 4HP24 (LATE MODEL 11/89 AND NEWER)- EGS 1.XX
08 Solenoid valves 1 & 2 EGS PIN16, 17 Transmissio pin 5, 6 -Short in wiring
A5S 310Z (5HP-18) - EGS 7.XX
08 Shift Lever Position L2 8 Vehicle accelerated while shift lever in park or
neutral position
Engine was started and the EGS control has not
detected park or neutral position signal
A5S 560Z (5HP-30) - EGS 9.XX
08 Shift lever position L2 8 Vehicle accelerated while shift lever in park or neutral
position
neutral position
position
Ainult lollid teavad kõike...
